When the test gauge is leaking...
Boon
Member Posts: 260
So I've tried testing like three times, bubble tested everything ... except the gauge! The schrader valve is leaking. Now what do I do?
I pulled a cap off of my car wheel and tightened it on there but it still leaked. Maybe I'll try another cap.
Is there something smart that y'all do when this happens?
DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.
We always have a spare core or two on hand when we do a pressure test. 99.5% of the time when I have a leak it is the test assembly, always the first thing I check if the pressure drops. I think you can get them from most bicycle repair shops for not too much $. A good schrader tool, or a cap (like the ones in the pic) that have the tool formed in work well.-1
a few times I have vainly looked for a leak that didn't exist......except on my test gage or hose.......someday I will get smarter0
That is a frustrating lesson that we have all learned
I have also had gauges develop a leak up inside them.
On large radiant air test I eliminate the schrader valve, screw a 1/4 ball valve and the quick couple that matches my air hose.
It eliminates the tire stem leak potential and really speeds up the fill. No need to hold the air chuck either.Bob "hot rod" Rohr
Living the hydronic dream2 -
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
