Almost Done
Dan Foley
Dan Foley Member Posts: 1,268
Brian, Poppy, Dragon and Pedja have been working on this project in The Plains VA for the better part of two years. We are hitting the home stretch now. The main house is about 26,000 sq. Ft.
  • Dan Foley
    edited January 2017
    Some interior shots of the main house. Many hours were spent with the architect to make the mechanicals blend in with the architecture.
    LionA29
  • Dan Foley
    edited January 2017
    The mechanical system is geo based with boiler back up. Six water to water units provide hot/chilled water for the radiant heating and cooling system.
    12 packaged geo air units provide 2nd stage cooling, ventilation and de-humidification.
    Two 120 gal tanks for DHW are heatied by the boiler. DHW pre-heat off the geo de-superheaters store in two 80 gal tanks.
    LionA29Canucker
  • Dan Foley
    The 12,000 sq ft guest house is next. It will also have geo based radiant heating and cooling with boiler back up.
    LionA29
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,682
    That's almost as nice as the job you did at Erin's house!
    Retired and loving it.
    Dan Foley
  • KC_Jones
    KC_Jones Member Posts: 5,907
    WOW, that is impressive.
    2014 Weil Mclain EG-40
    Dan FoleyRomanGK_26986764589Solid_Fuel_ManCanucker
  • LionA29
    LionA29 Member Posts: 255
    Impressive! @Dan Foley
    Dan Foley
  • Fred
    Fred Member Posts: 8,542
    Beautiful home and amazing mechanicals/system @Dan Foley !
    Dan Foley
  • adambnyc
    adambnyc Member Posts: 260
    The mechanicals are really awesome looking but I don't think I could ever sit comfortably in that house. Reminds me of one of those psychiatric rooms designed to test the limits of your stress.
    Call me old fashioned I suppose but some privacy and a wrap around porch and I'm a happy guy.
    LionA29BobCRomanGK_26986764589Dan Foleyrick in AlaskaNew England SteamWorks
  • Dan Foley
    They own 2,000 acres around them. There are no neighbors.
    lchmbRomanGK_26986764589SnowriderCanucker
  • STEVEusaPA
    Is her house the same size? :)
    It's a shame you couldn't do an in depth video documentation, like TOH, but more than 10 minutes. This could've been a mini series.
    I'm amazed at all the phases-design, bid, install?
    Did you design/engineer the job? If not, did the designer/engineer allow your input (if they were smart).
  • Is this your retirement home, Dan? Nice job (as always)!
    That shot of the Viessmann Vitodens: What size 200, BTHB? What is the grey box next to the boiler, just above the horizontal blue raceway - junction box with relays (RIB's) on the perimeter? And what does the silver canister do just to the right of the low loss header - chemical feeder? And is the 3/8" threaded rod the only thing holding the expansion tank in place?
  • Dan Foley
    @ STEVEusaPA
    Thanks!
    The system was originally designed by a mechanical engineer. As the project evolved and radiant cooling was added, the original design was scrapped and I took over the mechanical design.
    When the job is finished, we may shoot video of the entire system if the owner allows.
    Here is a link to video shot in the early stages:
    https://www.youtube.com/watch?v=kTFlcVKbMUo
    Harvey RamerSolid_Fuel_Man
  • Ironman
    Ironman Member Posts: 7,851
    You're having too much fun! :)
    Great looking job. You are a real asset to this industry.
    Bob Boan
    Dan Foley
  • Dan Foley
    Thanks!
    The boiler is a Viessmann Vitodens 200 B2HA-112 (113 - 399 input). It powers the two DHW tanks and provides back-up heat for the geo system. It also supplies radiant heat for a six car garage through a heat exchanger.
    The grey box is a junction box for heat demands.
    The silver canister is a Fernox magnetic dirt separator:
    http://www.fernox.us/equipment/filters/tf1+delta+filter
    The expansion tank is hanging from a bracket like this:
    http://www.dutchtechusa.com/products/flexconsole-standard/
    All the weight is supported by the bracket. The threaded rod just holds the alignment in case it gets bumped.
  • Dan Foley
    Thanks, Bob !!
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    That's really cool! The ultra modern is interesting, how well does the Geo compare to LP as far as cost to operate in your area? Are you using the air handlers to control indoor humidity? What is the setpoint when you know you won't get condensation on the radiant surfaces?
    Great project, and beautifully executed as well!
    Taylor
  • PinkTavo
    PinkTavo Member Posts: 64
    With a family of 4....6500sf per person. One could go years without ever seeing anyone else! And, with only a 12,000sf guest house? At two guests they are being cheated out of 500sf each that their hosts enjoy.
    Dan Foley
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,893
    wow Dan That is a really cool project
    Ray Wohlfarth
    Boiler Lessons
    Dan Foley
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Great work, Dan! Hopefully the owner will have a full time maintenance/mechanical guy on staff.
    Dan Foley
  • Great video with you interviewing Poppy! Both of you are very candid.
    Dan Foley
  • Dan Foley
    @ Solid_Fuel_Man
    The geo was chosen strictly for aesthetics. The architect did not want any visible equipment outside such as condensers, chillers or cooling towers.
    The air handlers have two stages of cooling and will provide filtration and de-humidification.
    The primary purpose of the radiant cooling is to capture the solar energy from the large expanse of west facing glass that is 14' tall, with no overhang. All of the flooring is stone.
    The supply water temperature feeding the radiant cooling will rarely get below 60*F. The control system will calculate dewpoint through slab sensors, air temperature sensors and humidity sensors to keep the surface above dew point at all times.
    Solid_Fuel_Man
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    Phenomenal work, Dan, as always. Thanks for sharing!
    President
    HeatingHelp.com
    Dan Foley
    Haha! I think my house would fit inside their closet.
    One thing we do have in common is that our mechanical rooms are works of art. Maybe I should host a wine tasting in there too. ;)
    President
    HeatingHelp.com
    HillyRomanGK_26986764589
  • NYplumber
    NYplumber Member Posts: 503
    You and your crew did a swell job!
    :NYplumber:
    Dan Foley
