Need excellent steam Contracter philly area
DanaS
Member Posts: 7
Hello all. After numerous horrible experiences I found the wonderful Joe Starosielec on here. He was able to get my Broomell vapor system working quite well. I have been unable to reach him as I heard he switched companies but I am desperate. I am getting no pressure at all in boiler and the house is cold.i need someone ASAP who is knowledgeable with this type of system in the Philadelphia/ Montgomery County PA area. Thanks!!
Joe seems to have gone to work for another company elsewhere, and so does not seem to be available.
Therefore, can you see whether the boiler will fire as the temperature drops?
If not, is there water in the sight glass tube on the boiler?
Answer these questions, and we will try to diagnose, and guide you towards a solution.--NBC0 -
@EzzyT do you go to Philly?0
Try @STEVEusaPA.Bob Boan
@DanaS there you go. Contact EzzyT you won't be disappointed.0
- 120 Geothermal
