stadler thermostat
eberle type 111 1702 91 RTR-E-6722 anyone know where I can get replacement for this thermostat 3 wire
    Jamie Hall Member Posts: 27,379
    Which side of the pond are you on? If the east side, try http://uk.rs-online.com/web/p/mechanical-hvac-thermostats/3750180/
    They list it as a discontinued product, but list an alternative.
  • JeffM
    JeffM Member Posts: 185
    Do you need it to look similar to match others in the building, or just function the same way? If it doesn't need to match, most current Viega thermostats will work (Stadler became Viega in the US).
