Glowcore boiler replacement
TomHolla
Member Posts: 1
I have to replace a Glowcore GB90 and was curious if there was a similar model. We had many problems with this junk. We also had to drill 2 1/2" exhaust and intake holes through our logs, so a model with similar external fittings would work best. Cold water manifold lines and 2 1/2" intake on left side, hot water return and exhaust on right side. We live at about 6000 ft and run on propane. I would like to buy a well known brand rated at 90000 BTU or higher. Any suggestions? Thanks
Wow! A Glowcore (aka Blowcore) still running till now...
I like the IBC HC wall hung boiler.
vents in 2" pvc or the like.
Bottom tappings.
http://ibcboiler.com/ibc-products/hc-series/0 -
I'm surprised that your Glowcore lasted this long. They and Hydrotherm's Pulse boilers were the first American experiments with condensing boilers.
I like Lochinvar products. The Knight KHN110 (floor mounted) or the WHN110 (wall mounted) would be your size:
http://www.lochinvar.com/_linefiles/KHN-02 B.pdf
http://www.lochinvar.com/_linefiles/WHN-02.pdf
Do you have in-slab radiant heating?
The only problem is that they both have 3" flues that would be too large to fit through the existing 2½" holes. I would calculate the heatloss of your house to see if you can get by with the next size down (the -085) which has a 2" exhaust and make-up.
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
