Riello burner locking out
Aaron_in_Maine
Member Posts: 315
in Oil Heating
I have a customer I installed a Biasi B10-3 boiler over a year ago. The issue is every time the power goes out the burner does not start up until someone hits the reset button. Has anyone run into this before I have never seen it. The customer is a snowbird and is very worried about his neighbor having to reset his burner.
Bad primary?All Steamed Up, Inc.
Consulting0 -
I'm not a riello expert, just a normal dude, but getting a new primary control would be my 1st guess.0
That was my thought was primary. Just curious if anyone has had this issue before.
Usually controls with a recycle feature shouldn't lock out, but that is with a black out, and not always a brown out. I would suggest a surge protector also0
I agree. Maybe the first power failure smoked the primary when the power came back on.
If that's the case, it should be addressed as @billtwocase statesThere was an error rendering this rich post.
- 120 Geothermal
