Series 100 Pump
maslaten
Member Posts: 5
Installed a new bearing assembly with impeller. When I turned on the water, the oil well filled with water and water was leaking out of the weep hole on the bottom of the assembly. Did I do something wrong? I took it back apart and checked the gasket and it was where it was supposed to be. Could the new one have a bad seal?
Neat trick Dan. Sounds like the shaft was possibly hammered0
That goes for any pump with a coupler, Bill, but especially for the small ones. There's a lower pressure at the impeller's eye when the pump first starts, which causes it to move forward if there's any play at all in the shaft. B&G taught me that when I was a kid in the business.Retired and loving it.0
Thanks Dan, I'll try that. I ordered the bearing assembly with the impeller assembled, guess it could have been installed incorrectly from the assembly plant.0
Was it a factory-original part?Retired and loving it.0
Not sure what you mean. it is a B&G ordered through partshouse.com
Excuse me, supplyhouse.com0
There are folks who rebuild the parts and sell them. Sid Harvey's is a good example of this and they do a fine job. Others may miss that fine point about supporting the shaft that I mentioned. I don't know if supplyhouse.com sells factory-original repair parts or offers third-party products as an option.Retired and loving it.0
I took it apart and reinstalled the impeller per your instructions. Still leaks. Can I assume it is a bad assembly?0
YesRetired and loving it.0
- 167 Indoor-Air Quality
