Taco isolated end switch wiring help
adavis
Member Posts: 11
I am installing a taco SR502 Switching relay connected to a crown phantom boiler for a 2 zone radiant floor heating system. All thermostats and zone pumps are connected to the switching relay. The taco end switch terminals are marked X X which would be wired into TT on the aqua stat. but the low voltage terminal board on the crown boiler are marked Heat T'stat R W C, how would I wire X X into this boiler labeled RWC to fire the boiler during a heat call .
Does it matter which wire goes to X X,
X X XX
RW WR
Thank you for your time0 -
You're welcome.Bob Boan
Thank you Robert O'Brien0
