Economite Conversion Burner Model E20A
bobbuck
bobbuck Member Posts: 8
Does anyone have an Economite E20A conversion burner manual? It has a tag on it saying it was installed in 1980. Can you help me, the motor is starting to squeak.
  • Fred
    Fred Member Posts: 8,542
    Google Economite E20A Manual. Looks like there are several sources for that manual that can be downloaded.
    Steamhead Member Posts: 18,306
    That is a special motor- it contains a centrifugal switch that holds the gas valve closed until the motor gets up to speed. Might be hard to find.
    The E20 is not a flame-retention burner, but an evolution of the LoBlast burners that Midco sold in the 1940s and 1950s. My experience with it is that unless it is installed in a boiler with a long narrow firebox, the flame will slam the back of the firebox, which can result in poor combustion and high carbon monoxide. In such a case, I like to replace the E20 with Midco's EC-200/300 unit, which will fit the same mounting flange as the E20 and give much better combustion.
    What boiler is your E20 installed in?
    Consulting
    kcopp
  • Tim McElwain
    Tim McElwain Member Posts: 4,658
    That motor has oil cups on it and can be lubricated. Also make sure the squirrel cage is clean. I have all the manuals on all the E-20's ever made. E-mail me and I will send you a copy based on model and serial number of your unit. E-mail is gastc@cox.net.
    kcoppbburdSuperTech
  • bobbuck
    Thanks Tim McElwain. I have sent you and email with requested information. Will let you know if I am able to keep this old relic going.
  • bobbuck
    edited December 2016
    The only name I could find on the furnace is Hercules L-618. It was converted from Oil to gas in the 80's.
  • Tim McElwain
    The instructions went out in the mail today. Locally E-20 parts in the past were handled by
    R. L. Gourley
    80 Felton Street
    Waltham, MA 02154
    Phone 866-309-2680
    Not sure if there is anything around for Midco E-20's.
    kcopp
  • bigfischusa
    bigfischusa Member Posts: 2
    I gave a ec20a set up to fire @131mbtu in 1981 complete unit has been sitting in basement for over20 years,will not work in my h5 85 thermo pride can part out or sell unit ,motor runs draws only 1.3 amps manual spark works
  • bigfischusa
    correction I have an ec20a economite burner
  • burnhaminmycellar
    burnhaminmycellar Member Posts: 1
    I have an ec20a economite burner e20a , I can light the pilot hold the button and wait a long time, but when i turn the knob to run it won't and the pilot light goes out. I'm looking for tips dave 978-424-7171
    EBEBRATT-Ed Member Posts: 19,863
    Could be the thermocouple.
    kcoppmattmia2
    mattmia2 Member Posts: 15,962
    or the pilot burner is dirty or out of adjustment or disintegrated
  • GW
    GW Member Posts: 5,147
    or the gas valve's pilot valve electromagnetic is dead. If you're getting good Milli-volt and the pilot won't stay, try a new gas valve
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    assuming it is a combo valve. can test it with an ohmmeter.
