Propress failure.
Harvey Ramer
Harvey Ramer Member Posts: 2,281
This just in. Never happened before, never hope to see it again.
    Steamhead Member Posts: 18,187
    Wow- how much extra time and money is that gonna cost you?
    Consulting
  • ratio
    ratio Member Posts: 4,176
    Tool, procedure, or fitting failure?
  • Harvey Ramer
    It cost to much extra time and money. What a pita.
    It was a fitting failure. Didn't become apparent till a year or 2 later.
  • Tom_133
    Tom_133 Member Posts: 958
    Ive had one fitting failure and but sadly I have only done a total of 200 fittings. It was on the center section of a 3/4 tee right behind the branch. you could see that it happened in the forming process. I don't know if they press them or stretch but mine happened at the factory and cost me some dollars!!
    Sorry to see that Harvey, I guess the old adage still remains "everything has its weaknesses"
    Tom
    Montpelier Vt
    hot_rod Member Posts: 26,574
    What a bizarre stack of fittings! To get from 1/2 to 3/4" copper, pump to pipe?
    I wonder what tongs were used to squeeze that fitting, the imprints look unusual.
  • delta T
    delta T Member Posts: 884
    I had some failures on two elkhart press MIP's too. And, to clarify, no the leak was not from the threads, the fitting cracked perpendicular to the pipe an 18" above the o ring about a year after installation.
  • Bob Bona_4
    I know HR, sweat, press, and thread, all in 4"!
  • j a_2
    j a_2 Member Posts: 1,804
    Oh no....Looks like a jaw issue..From here anyway....I do not like progress on looks alone...But in today's world I would use it if I was worried about fire with tourch ....viaga fitting?
  • Harvey Ramer
    OK, ok. So it's apparent that the fitting art will need an explanation. Lol Made sense at the time. Still does. The pump that was there before was a CI 007 with standard 3/4" threaded flanges. I told the ho it's got to go and we put in a real dhw circ. It's up in the ceiling. Not a good place for a torch. The other side had a check sweated in directly after the 1/2 by 3/4 male adapter, so no room to cut it off and put in a 1/2 X 3/4 reducing press coupler. I yanked the pump, unscrewed the flanges, sweated 3/4 stubs on the pump, slipped the female press adapters on the stubs, put it in place and screwed the press adapters on the copper adapters, and then press press and I was done.
    There you go. And I won't forgive you anytime soon for making me do all that extra typing. Lol
    Its not a tool issue. I've been using the same tool and jaws for years. It's a fitting issue. My guess is the fitting somehow got hardened to much and cut and cracked on the press.
    GordyBob Bona_4
  • Bob Bona_4
    Lol. I put in that UFT80 last week, prefabbed the supply onto the boiler on the ground, it ended up being 4" lower than the existing piping once hung. Not even thinking, I'm offsetting with 2 - 90s. Ugh :)
  • Gordy
    Gordy Member Posts: 9,546
    Is it my eyes or is the depressed area of the crimp in the failed area gone? Or just dis colored?
    I would say your suspicions are correct Harvey. Question is did the fitting get hardened to much from Factory, or handling? We all know what happens to soft copper, and brass through work hardening.
  • Harvey Ramer
    @Gordy
    Your eyes are not deceiving you. It's seeping out of the crimp indentation.
    Have, or will you send it to the manufacturer for analysis?
  • Gordy
    Is it possible that one of the jaws were fouled with material on it. Thus causing it to depress that crimp beyond limits.
    I know it's a stretch, and that material would have to be harder than the brass.. it's all I got......
    j a_2
  • kcopp
    kcopp Member Posts: 4,628
    I had an Apollo copper 90 fail on me one time last year. Of course I was in a crawlspace and had to crawl out about 200' to get another one. That was a copper 90
  • Harvey Ramer
    I guess maybe i should send it in. They would probably be interested in determining the cause.
    Gordy, there was nothing on the jaws. It was strictly a fitting failure.
  • Gordy
    I'm sure you would be interested too.
    It can really help a manufacturer get a handle on a potential problem if they can do forensic work ups.
    Could be a bad alloy batch, forging or machining problems, tooling out of spec.
    Whatever the cause the sooner they find those the better chance of making a correction.
  • j a_2
    What's the manufacture of the fitting,and jaws used to do the crimp....Do the pro press tools need factory checking after so many presses..Seems I remember something about that they went down on auto shut down after x amount of presses....
  • Gordy
    Good point @ja seems though the press would be less from wear on the jaws.
  • j a_2
    Just seems out of the norm..to me...curious about what brand fitting and what make tool was used....
  • kcopp
    Its a manufactured product.... how many times have we seen sand holes in a malleable fitting or a mis-made copper or PVC fitting.... Not normal but it does happen. Certainly a pain in the butt. It would be nice if the Mfg were to comp you some $$.
  • j a_2
    Would he compensate you in Yen,or Won, or Pesos....lol.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Send the manufacturer of the fitting a bill. CC the wholesaler you bought the fittings from.
    SWEIkcopp
  • Harvey Ramer
    I looked for the fitting the other day. It's already disappeared. I'll be taking this one on the chin. I have also run across 1" 90's that didn't actually fit over the pipe. I only buy Viega for fittings. I use some other brands for valves and components. Primarily webstone.
  • Tom_133
    I am sure all of you know this but just in case. If you buy a preassembled copper manifold that has been make with a T drill and then brazed, even with L copper don't use a progress fitting. I did and it wiggled, so I called the manufacturer of the manifold and he said "that we can't use propress with his manifolds" something about the brazing making the copper to flexible. He also said he sent a memo to all his wholesalers about the problem. That was a few hundred dollar whoopsie!
    Tom
    Montpelier Vt
    j a_2
  • j a_2
    @Tom, it does get crazy with all the new and different technology,,,,It stinks that you had to eat that redo...Just my opinion, but, there will be more to come....Manufactues in my opinion care only about the bottom line...
  • Gordy
    You will find it when looking for something else
    Solid_Fuel_Man
  • I've said it before and I'll say it again "You can take my soldering tank away, when you can pry it from my cold dead hands"...
    Thanks, Bob Gagnon
    Solid_Fuel_Man
