What's this doing?
Ironman
Member Posts: 7,827
Looked at a job with 1920 gas boiler and 2 pipe Dunham traps and packless radiator valves. No Dunham vacuum components.
Can someone tell what this is doing. It looks like a bucket trap, but the way it's piped, I can't see its function. It's high above the boiler on return lines from the 2nd & 3rd floor.
Bob Boan
a main vent i betgwgillplumbingandheating.com
that looks like a float vent. you usually see them with a boiler return trap which may have already been removed. was probably a vapor system at one time0
I believe there would usually be a check valve on the horizontal below that Dunham air eliminator.--NBC0
It's part of the Dunham Home Heating System actually. It has this float inside and an air vent on top.0
It appears that this is what I have:
I couldn't find an air eliminator that looks like the one we've got, but the piping and system description match up.
Bob Boan
Another question: can TRVs be installed in place of the Dunham packless valves?Bob Boan
That's right, it's an air vent. There's probably a vacuum check in the top, which you should remove.
Tunstall may be able to supply inserts for those packless valves that would turn them into TRVs.All Steamed Up, Inc.
Consulting-1 -
How about replacing it with a BigMouth or Gorton #2?Steamhead said:That's right, it's an air vent. There's probably a vacuum check in the top, which you should remove.
Bob Boan
That's doable. Most of these have 1/2" threads where the vacuum check screws in, so it's a simple matter to put a vent there.Ironman said:
I'd use the Gorton. The Dunham unit does have a float in it which is supposed to close against water, but after all this time we don't know if it still works. The Gorton has its own float, whereas the Big Mouth does not.All Steamed Up, Inc.
Consulting-1 -
Doesn't look like the Dunham Air Eliminator I have their old catalogs. Looks like their DB Type OB inverted bucket trap someone has converted into a poor mans air eliminator.
You could check that the float works pretty easily by opening a union downstream and filling it with water.
Or you could make an new float trap with air vent by buying a H pattern F&T trap. You'd remove the air vent and plug it in the head. We make those as float traps. Then take a street elbow from the other inlet, add whatever riser you want and add a Big Mouth. That way you'd have the fastest venting and be sure that the float mechanism works.
It could very well be a Sarco or Hoffman Air eliminator. I have some NOS if you want onePeter Owens
SteamIQ0 -
Take a look at what's cast into the unit. It should say it's an air eliminator. I've seen this type in the field- IIRC this is an earlier version than the one we usually see.All Steamed Up, Inc.
Consulting0 -
This is the best pic I could get today standing on top of the boiler:
I'm gonna have take a small extension ladder back with me next time to be able to get up to it.
With it being 8' above the boiler's water line, is it even necessary?Bob Boan
Def an air eliminator, I bet it works almost the same as a bucket.Peter Owens
SteamIQ0 -
I told you what it is @Ironman!
The vent connection is 3/8". You have a Dunham Home Heating System and it's listed in The Lost Art. There is just a simple float inside which I attached in my first post. If the pressure rose too high the water would raise the float and seal the vent. 0 -
Never doubted you or Steamhead. I just never saw one shaped like that (even in old books) and I thought that Peter may have been on to something about it being converted into an air eliminator.Danny Scully said:I told you what it is @Ironman!
So, with it being mounted 8' above the boiler is it really necessary? Could I just replace it with a main vent?
Bob Boan
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
