Radiator valve
Neild5
Neild5 Member Posts: 203
On a one pipe steam radiator system I understand the concept of either full open or closed, and why it is not recommended to shut the valve because steam may be able to get past the seal since they will end up looking like this. So what is the advantage over just using a 90 and a union?
  • I was wondering that too...
  • gerry gill
    gerry gill Member Posts: 3,083
    well, if you replace the washer, you can turn off the radiator.
    otherwise, there is no difference.
    gwgillplumbingandheating.com
  • Abracadabra
    The advantage with a valve is that you can leave the heat running while removing a radiator for repair/painting/etc..
