Radiator valve
Neild5
Member Posts: 167
On a one pipe steam radiator system I understand the concept of either full open or closed, and why it is not recommended to shut the valve because steam may be able to get past the seal since they will end up looking like this. So what is the advantage over just using a 90 and a union?
I was wondering that too...0
well, if you replace the washer, you can turn off the radiator.
otherwise, there is no difference.gwgillplumbingandheating.com
The advantage with a valve is that you can leave the heat running while removing a radiator for repair/painting/etc..Neild5 said:On a one pipe steam radiator system I understand the concept of either full open or closed, and why it is not recommended to shut the valve because steam may be able to get past the seal since they will end up looking like this. So what is the advantage over just using a 90 and a union?
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
