PERT tubing
kcopp
Member Posts: 4,433
Now that Watts has started selling this product more have any folks here used it in a slab application. I have a contractor friend who linked a section and wants to heat it up to get out the kink... vs a coupling in the slab. Getting conflicting info from Mfg reps.
I've got about 5000 feet of it in my home and it's all we use for radiant jobs0
Ever had to fix a kink?
Are you using the Hydronic Alternatives brand?0 -
I'm old school with kinks, I cut it out. I honestly didn't know one could heat it until recently. Yes I use the HA.0
That's odd, I would recommend calling HA, if Paul isn't available ask for Steve.
I must say I don't ever recall kinking a slab run, yet the several times I've kinked a 3/8 line for dry floor I just used Veiga couplings
I suspect you've been give lame advice, give ha a buzz.0 -
Thanks..... it wouldn't be the first time I either misunderstood someone or got bad direction.0
I am almost positive you can heat it right up let it cool you're good to go.0
This is the Watts product. I presume it is the same basic product as the Hyd Alt or the Roth.0
Paul knows the Dow Chemical dudes that make the resin, he knows all this stuff...which manufacturer has what spin on what tube
Steve can answer your questions if Paul is out.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
