How's the near-boiler piping?
  • adambnyc
    adambnyc Member Posts: 260
    Equalizer looks too small, riser is too short. Should be 24" min above the water line. Boiling water jumps. A lot of the pros are going for 36" risers. I see your under space constrains, this is a great place for a drop header.
  • nybigapple
    nybigapple Member Posts: 61
    How easy would it be for a professional to add a drop header? Could it be added easily enough to the existing piping or would it require complete repiping?
  • adambnyc
    Eh, difficulty level is all the eye of the beholder I suppose. Not difficult provided nothing else is wrong with the boiler.
    j a_2
  • nybigapple
    edited December 2016
    Let me ask in another way. How long do you think it would take a typical professional to add a drop header(if there aren't any problems)?
    I'm trying to decide if I should look into getting some things done now, or hold out till after winter is over. My main concern is being able to finish it within the course of a day without issue.
  • EzzyT
    EzzyT Member Posts: 1,377
    Would require a complete repipe. Before a repipe is proposed I would see if that boiler is properly sized and then go from there.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • nybigapple
    Ah that's the piece I was looking for. A complete repipe means I won't even bother looking into it till after winter. Thanks!
  • SWEI
    SWEI Member Posts: 7,348
    Bullheaded riser take-off on top of all that.
  • lchmb
    lchmb Member Posts: 2,997
    a complete repipe may be cheaper than the extra fuel and discomfort you'll have this winter... It would make for a long day but betting with prep it could be done in one day...just have coffee ready at 6am...
  • j a_2
    j a_2 Member Posts: 1,804
    g
    Smart move, got some visible issues there.....maybe when you start getting proposals you can post them here.....less pricing of course..We will give you 3 or 4 basic questions to ask him about steam....If he can't answer them he may not be your man...
  • furnacefigher15
    furnacefigher15 Member Posts: 514
    Before you start looking into repipe
    1- Does it work now?
    2- How old is the boiler?
    3- Have you done the basics yet? - washout (fire and waterside)
    I would not advise doing a repipe unless the boiler was 5 years old or less unless the existing piping is somehow preventing heat function which I doubt.
    Repipe when the boiler is replaced, for now insulating the piping will reap you cheap and easy (you can do yourself or with cheap labor) rewards in fuel consumption.
