Insulating the Main and the basement pipe runs ?
misterheat
Member Posts: 158
I go back and forth with insulating the pipes in the basement. If they aren't insulated , that heat in the basement makes it way through the house, correct? How much of a time difference could it make per cycle if they aren't insulated , 5 minutes ? The whole house seems colder since I insulated them . What are your thoughts?
uninsulated pipes are in fact radiators. Whether you desire the effect of the radiator pipe is up to you.gwgillplumbingandheating.com
My original intent was to cut run time down for the boiler. Now I think I would rather let the heat out down there . Basement is not a living space here. I have to believe that the heat down there makes it way through the floor( which Is much colder now) and helps with the heat slightly on the second floor. Thanks for the reply.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 855 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
