Burner opinions
Dave0176
Member Posts: 1,177
Doing a gun conversion on a steam boiler. Looking to get opinions on brands Beckett or Carlin?? I know the Beckett is rather new, this is why I'm asking??
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
I presume you mean gas burner... I use the Carlin EZ gas.
Simple set up. Reliable.
I have used the Riello a couple times but only w/ Buderus boilers.0 -
All good. Carlin has been steadfast for Conversion burners for many years. Workhorse..easy set up. Any Becketts I Have worked on or come across are very good too. Riello can be finicky on set up but fine too. Mad Dog0
Never had a problem with the Carlin gas burners.0
What boiler are you converting?All Steamed Up, Inc.
Consulting1 -
@Steamhead it's a Weil McLain SGO-3 about 4 years old.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
The EZ-Gas will do fine.All Steamed Up, Inc.
Consulting-1 -
Thanks guys Carlin it'll be......DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
@Dave0176 Order the gasket kit when you get the burner0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
