Laars endurance combination boiler help
deloristhompson28
Member Posts: 1
My system has recently stopped supplying heat. I can turn up the SP setting and all three lights will turn on but once it reaches the new setting it shuts down with zero heat coming from the baseboards. The reset button doesnt seem to kick start it and turning the thermostat up doesn't work. Turning the breaker off and on seems to do it but sometimes have to do it 4 times before it finally works right. I can hear the relay clicking but that's it. Any suggestions?
It sounds like you have a lack of flow to the radiators.
If the problem is solved by resetting the breaker, that would indicate that the issue is electrical. A bad pump relay would be a guess...."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
