2 Year old Burnham Steam Boiler Install
Mike2242
Member Posts: 4
Customer says it doesn't run well and makes a lot of noise.
They can't get the original installer to come back.
What do you think about it?
Oh my Lord. Where to begin?0
I wanted to post more of the piping but the pictures are too blurry to see anything.0
Come on this is a joke....Correct0
Someone got in over their head. Too bad I can't make heads or tails of the piping.Miss Hall's School service mechanic, greenhouse manager,teacher and dog walker0
They used one supply on boiler, plugged the other. one 4" line is connected directly to old pipe. You can almost make it out in first picture where they added a flange and two elbows to connect it.
Return is what you can see on the pic with the water feeder, other side of boiler plugged.
The wiring is as it was since the install two years ago. Scary thing is, they were running it until this season.0 -
That looks like a do over to me. I can clearly see why the installer won't come back:
https://www.youtube.com/watch?v=Y7KjQrUVJ100 -
We told the customer the near boiler piping needs to be redone, rewire everything and get it right.
First we have to go back and take a walk thorough inside to make sure its sized properly to begin with, also verify if its a one pipe or two pipe system and all that madness.
Originally thought it may have needed skimming or had a slow return since it was working for two years, but once we saw the boiler room we told them we need to come back and spend some time on it.
Knuckleheads provide the rest of us with work!! Slob!!! Hope they don't have a license and get caught!!0
low bidder wins again0
Getting so tired of seeing this stuff here and in the field....0
Heating Hell candidate? Erin can move things...0
Typical NYC installation....i see this everyday and most people think its fineASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
That's a V-9 from Burnham Commercial. Is this multi-family?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
