twinning tanks
Hello, I found this: http://www.hotwater.com/search/?q=manifold#gsc.tab=0&gsc.q=manifold&gsc.page=1 Go to the top listing, "electric water heaters" and you'll see headers and model numbers.
Yours, Larry0 -
I know you mentioned AO Smith's manifold kits, but I used to pipe multiple heaters/tanks like AO Smith recommended, but recently switched to reverse return and prefer it, especially for more than two. Just sayin..0
nice do you have a piping diagram for that
everyone other than ao smith shows reverse return on their install manuals.
http://www.statewaterheaters.com/literature/instruction-manuals/commerical-gas/sandblaster-self-cleaning-manual-197290/
see piping diagrams starting on page 400 -
Another option would be to use balancing valves
A couple 132 quicksetters works well as you can view the exact flow in both tanks. Saves piping and fittings and related labor, insulation and heat loss. Idronics 17 on page 24 has an example
Living the hydronic dream0
- 50 Industry Classes
