Furnace gas valve problem help! It's cold!
ali6669
Member Posts: 4
in Gas Heating
I have a gas furnace that will turn on but won't ignite the burners. The electric coil igniter glows red hot, Once it gets hot I can hear it try to click on but it does not ignite like there is no gas getting to the burners. We have had 3 different people here to fix it and they get it running by basically doing nothing, only disconnecting and reconnecting various things, then it quits working within 3-20 hours. The last repair guy was trying to replace the gas valve but said it might not even fix it and did no testing or anything to diagnose the valve as the actual problem so I didn't want to spend the money for nothing. We can test with a multimeter but I'm not sure exactly what to test or what the reading should be? Any help is appreciated even to get it running temporarily cause it's Sunday evening and only 45 degrees in my house. Thanks!
There is definitely gas getting to the gas valves, we disconnecteted the pipe to check and had the gas company here. I put multi meter on the two wires going to the gas valve and get a reading around 10v while igniter coil is heating then it goes to 0.0v when I hear it click to try to ignite burners...is this correct or am I even testing the right thing?0
Yes hot water tank is working and no the so called pros literally turned a knob or 2 then left when it fired up...of course the turning of knobs only works for them hah0
Send some pictures of the controls and also Make and Model of the furnace.0
Tim and I both have been waiting for your next posting........0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
