leak on a staple down overpour
greenhead_2
Member Posts: 13
Has any body tried to fix a staple down leak from the ceiling below, cut sub floor and bypass leak? Its under a C I tub that was glued to a floor and the only way is under neath.
Are you sure it from the heat? Pretty odd it would get damaged from under a tub...
- 52 Job Opportunities
