If our community has helped you, please consider making a contribution to support this website.  Thanks!
what wifi thermostats work best for steam
                    gerry gill
                    Member Posts: 3,083
                    hi Guys- im getting lots of requests for wifi thermostats. Which ones work well with steam? i cant seem to gleam that info from honeywell.
                gwgillplumbingandheating.com
            Ignore this if your looking for a wireless model - I should have read the question more carefully!
In 2010 I installed this thermostat
Honeywell RTH6450D1009 5-1-1-Day Programmable Thermostat
It works well on my single pipe steam system and has had no problems. You can't select cph as such but setting it to gravity hot water seems to work fine for me.
It was well under $40 at Amazon, I'd deem it a good value for the cost but I'm sometimes known to squeak when I walk.
3PSI gauge0 -
            thanks Bobgwgillplumbingandheating.com
            The Honeywell 8000 or a higher end variant ( 9000 IAQ , etc. ). I prefer the separate internet gateway just for the reliability of connecting and set up ( especially on someone else's network infrastructure or hardware in general ). These stats have the adjustable cycles per hour feature and intelligent recovery.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
            I have the Honeywell 6580 and it works good. If you have a 2-wire thermostat, Honeywell will need 3-wires Had to run an extra wire for C terminal that brings 24v to the thermostat.
Several persons said the Nest is easy to install and works with the 2-wire from old thermostat.
Might be a better choice for easy installation.
Good luck @gerry gill0 -
            thanks for the info. I will look into those.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.2 -
            I will throw in my thoughts as a homeowner and have 3 wifi thermostats in 3 different locations, all running steam.
All of them are between $200 - $250, There are also very expensive Redlink Honeywells that I did not want to get into.
On all 3 of them I have turned off all "learning" features and set at a constant temperature during the day, with a minimal setback at nighttime.
The Honeywell wifi
http://yourhome.honeywell.com/en/products/thermostat/wi-fi-smart-thermostat-rth9580
Is a solid choice, it has worked perfectly the past few winters, no downtime.
-Solid performer
-No Runtime history
-Requires 3 wires
-No remote sensors
The Nest
Has been pretty solid recently, but the first 2 years I had it their product team was sending out updates in the middle of the winter that would make some thermostats go offline and stop working. You have no choice to opt out of the updates that Nest pushes out.
-Works ok
-Daily usage report
-Can use 2 wires only
-No remote sensor
-Tech support is by FAR the worst of any company I've dealt with
Ecobee 3
I recently put this one in with my new boiler. It is by far my favorite. Where I previously had to worry about where I mounted my thermostat, with this one I can install remote sensors anywhere I want (within 45ft) and use those remote sensors to either run the boiler or purely informational. The online portal is great allowing me download all the runtime data in excel and get data every 5 minutes
-Remote sensor capability
-Online portal with lots of reporting data
-Requires 3 wires, but they sell a 2 wire gizmo that supposedly lets you use 2 wires only
            thanks Newbieinqueens..thats excellent feedback.gwgillplumbingandheating.com
            Honeywell has a demo account in their Wi-Fi app. I keep it on my phone to show prospective customers. (Also my brother's place, but that's just for fun.)0
            I just installed an Ecobee and so far its great. The install was a breeze and they have this clip on set up which makes running the wires easy and maintenance super easy. The remote thermostat is a great feature for steam I found, since my first floor heats a little uneven. I had a Honeywell for years (the first gen one that allowed for a wireless adapter) and that was also good, I assume they have only gotten better.
I've read (never seen) that the Nest can go a little weird since it tries to learn from your heats behavior (not sure I understand that). Seemed overly complicated to me.0 -
            The new Honeywell T-Series covers a wide a range of models (all the way from a non-programmable single stage up through two different Lyric WiFi models) on a common backplate. The TH6220U and above support a wired remote sensor (either indoor or outdoor, though not both.) Contractor models come with a longer warranty than retail models.
We just got one to play with and have found that they have independent CPH settings (from 1-12) for each heating and cooling stage.0 -
            Thats really what i was looking for. Adjustable cycle rate. I knew the Nest didn't really have one for steam, so i was wondering about the others. Thanks everyone for your input, as it really did help. This concept seems to be the latest rave for customer desires. I'm not much of a techie, or as i like to say 'there is a reason i work on steam', so your input is greatly appreciated.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
            Gerry. I picked up a few Old style (mercury ) T 87s at a yard sale...IN ORIGINAL packaging....COVETING them...ha ha. Mad Dog1
            Where's the jealous button?0
i'm jealous too...can't beat liquid metalMad Dog said:Gerry. I picked up a few Old style (mercury ) T 87s at a yard sale...IN ORIGINAL packaging....COVETING them...ha ha. Mad Dog
            can you adjust the CPH on an Ecobee3? Or do you wing it by setting the temp differential?0
            Guess i had best get my dinosaur butt into the modern era and learn about some of these gadgets..thanks everyone for helping out and pointing me in a direction to investigate.gwgillplumbingandheating.com
            If anyone has the schematic on how to wire the Honeywell red link to the transformer or the like. I'd buy you a virtual beer!
Harry.0 -
            Ummm...
What, exactly, do you have?
            Well, right now I have a pro 4000 connected to the transformer and then all the controls wired to a single switch at the boiler. I would imagine the basic boiler electrical setup.
I am interested in a Honeywell red link and would love some help or a diagram on how to actually wire it correctly.0 -
            @Aveeight , @NewbieInQueens
Was hoping one of you may know this:
Thanks!Koan said:can you adjust the CPH on an Ecobee3? Or do you wing it by setting the temp differential?
            @hboogz
Does thi help at all ??
s3.supplyhouse.com/product_files/Honeywell-TH8321R1001-Wiring-Diagram.pdf0 -
            @hboogz, which RedLINK stat are you considering? The notation on the terminal strips of all modern Honeywell thermostats should match up, just a matter of swapping like to like. The lesser RedLINK stats can (5000, 6000 series) can run on batteries, but IIRC the 8000 and certainly the 9000 series need to have a wire landed on the "C" terminal to provide continuous power to the thermostat. If that wire is present on your 4000 stat you should have no problem, just use caution that you don't short out the transformer by letting the red wire (landed on the "R" terminal, or possibly "Rc") touch any other wires or metal. The RedLINK internet gateway just plugs in to the wall for power & an Ethernet cable to your internet device for connectivity. It takes about five minutes to set it up from start to finish, the instructions walk you through it.0
            If you have the requisite wire landed on the "C" terminal, nothing at all at the transformer. If you do not have a wire landed on the "C" terminal, you will have to look carefully at the stat wire, to see if another conductor is lurking under the jacket of the wire; you could possibly need to pull a new wire up to the stat. Assuming the stat you are considering requires constant power.0
@KoanKoan said:@Aveeight , @NewbieInQueens
Sorry don't know the answer to that one. I checked my settings through the web browser and there is no mention of it. Perhaps on the unit itself, but I don't have easy access to it.-1 -
            Is this a wifi conversation or a wireless?
In any case the Honeywell 6000 series has adjustable cph and comes wifi (you need 3 wires) or wireless (you will need the red link gateway for internet).
Obviously there are more expensive Honeywell thermostats
We did a wireless this past week and it occurred to me the Honeywell relay didn't have a good 24v output to power the wireless interface board. We installed an sr501 to make it work.0 -
            @NewbieInQueens
Thank you - getting ready to upgrade thermostats for a 2 pipe Hoffman Vapor system to which we will be adding central air next year. Finally got the boiler running well but it was short cycling bc of the thermostat an old Honeywell Cronotherm T-8090a. Adjusted the anticipator to 1.2 and working well now0 -
            To have gen 2 nest with 1 pipe steam. I haven't tried others but I am happy with results I've had.0
            My Ecobee 3 Lite lasted 1 week before it stopped working. It would call for heat, but not actually turn on the boiler. After having a heating contract our for 4 hours it came down to a defective thermostat. I am now waiting for a replacement.
            I got a replacement for this back in January and since then it has been working very well. Now I just need to focus on replacing my boiler.0
            It took someone four hours to figure out a thermostat wasn't closing the contacts?
            But the thermostat said it was calling for heat!
I've been bit by that myself. <sigh>
This is why people need to bust out the meter as soon as there's a problem.ratio said:But the thermostat said it was calling for heat!
I've got power going to the tstat, but none coming back, why? Next step go up and meter out the tstat.
Confirm findings by shorting R to W to fire the boiler up.
I use my meter more than almost any other tool when it comes to troubleshooting electronics or electrical problems.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
