Radiator bleeder question
kman_2
kman_2 Member Posts: 2
Hi guys, I just installed an old cast iron hot water radiator. The placement of the air bleeder seems suspicious to me. I also uncovered a plug in top right corner, which may or may not be where the bleeder should be. I have more questions but I will leave it at this for now. I would like some thoughts on the image. thanks
  • KC_Jones
    KC_Jones Member Posts: 5,907
    It must have been used for steam in it's previous life. That is the location of the vent on a steam system. You want to plug that and use the bleeder location you found at the top.
    2014 Weil Mclain EG-40
    Solid_Fuel_Man
  • kman_2
    Thanks KC, that makes sense
