Favorite Condensate Neutralizer Tank?
BigRob
Member Posts: 332
I like this one, but wow, that's a lot of money:
http://www.supplyhouse.com/Axiom-NT25-NT25-Condensate-Neutralization-Tank?gclid=CjwKEAiAsMXBBRD71KWOh6fcjRwSJAC5CNE1QO14qnDb9vEVxMMNVx9kf76a1zNuxMBfvIDIpQvOjhoCM3zw_wcB
This one isn't bad:
http://www.supplyhouse.com/Noritz-NT20A-Commercial-Condensate-Neutralizer-Kit-for-NRC1111-NRC98-NRC711-NRC661
Way too much for plastic! Any other cost effective options?
This one isn't bad:
That's how I did mine. Had a bunch of fittings in the basement. Only had to buy the male adapter and cap0
We make our own out of a 4" clean out tee and 4" threaded plug on the bull, two 2" x ¾" bushings on the run and a few handfuls of marble chips.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
Looks good. How much, $300?EzzyT said:
i did like what bob posted but I wasn't able to find it online0
I used the new SaniFlow condensate pump with built in acid neutralizer and have had no issues...at first I thought it was alittle loud but it 's not bad at all.1
Now that is some hydronic porn right there.. I like the zone valves and ecm's.0
@john p wow, I zoomed and went cross eyed for 20 min looking at that.....and I thought I was a bit OCD with my installs where "money and time are no object".
Beautiful work!
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Taylor thanks....not bad for an out of work pipefitter, huh?!0
Agreed, the Rubbermaid box works but after spending all the time and money I have on my system there is no way I was going to install a homemade device. I also love the idea of the condensate pump and neutralizing material as an all in one device....... Kinda reminds me of an ad I saw for motorcycle helmets..." If you have a $10 head, then wear a $10 helmet!" ....they meant for safety but you get the point.0
- 116 Geothermal
- 169 Indoor-Air Quality
