Trying to replace main steam vent...
genericnj
Member Posts: 80
... the main steam vent on my 86 year old system is not closing and I continually have to add water every two days. I purchased a Gorton #2 and a #1 to replace the old vent with one of these (#2 preferrably if it fits in the space). I have a 14in pipe wrench which I tried to use to loosen the existing air vent, but could not get it to budge...
Reading forums and posts, people seem to recommend PB Blaster, which I plan to pick up tomorrow, however I am looking for other recommendations on how to get the old vent off ...
It looks to be 3/4 in vent connected into a larger hole in the pipe via a bushing. I thought of also getting a 2-ft piece of pipe to put over the pipe wrench for some extra leverage.
Any other recommendations? Many thanks!!
Do the pipe/leverage thing and show it who's boss.
You'll get it off.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
If you're comfortable with a torch, I've seen first hand torching the plug ( vent in your case) for a few could get it easier to turn.0
The wrench and the pipe extension will get it done.0
Thanks folks - I got a 2" x 24" pipe on my way home from work--hopefully that will be long enough. I did not want to get one too long since this is in a tight spot at the corner with tight access. Also picked up a cheap $15 propane torch kit too, going to give it a try later tonight!0
Sadly the vent has shown me it is the boss... I tried the pipe-leverage method, but have failed... Have not tried heating the pipe yet to see if that will help... but that will be tonight's try0
I had the same problem recently with an old Dole vent. I wound up shearing the thing off with the pipe wrench and cheater. Finally took to cutting it down flush and then carefully cutting the threads out in pieces. Wasn't fun, but got it out.0
not fun ... so here is an idea i had ... please tell me if this is a bad idea ... the vent is installed into a bushing, which then goes into the pipe. Looks like 3/4 to 1 1/2 bushing. I am thinking of putting two pipe wrenches, one on the bushing, one on the vent so that squeezing the two wrenches will result in the vent loosening and then putting a clamp over the two wrenches to gradually squeeze them together..
Another thought is to try to get the bushing out, thus getting the vent out along with it, but the bushing doesnt seem to want to budge either...
The vent will be easier to remove than the bushing.0
The vent is probably brass whereas the bushing is steel/iron. The brass may twist off but is easy to saw out.
Put the heat to the bushing and then try it.0 -
Woohoo got it off! applied some heat on the bushing as advised and slowly but surely it let loose! Thanks everyone for great suggestions and encouragement!0
