pex piping radiant heat exterior dock
lefty1cad
Member Posts: 3
We are doing an exterior concrete loading dock. We wanted to do a reverse return radiant heat pex piping system the dock is 78' x 12' is it feasible.
Yes.
Now if you provide some more info, others will provide some more info.
Got a sketch with full dimensions/elevations?
Can it be insulated underneath and edges?
What zip code (for design temps)
For snowmelt I assume...
What design do you want-snow melt, or all the way up to drying, like a heli-pad at a hospital?
I don't know why you say 'reverse return', are you attaching this to an existing system or will this attach to a new boiler.
Glycol, heat exchanger....lots of details.There was an error rendering this rich post.
3
- 167 Indoor-Air Quality
