Look What I Found
RayWohlfarth
RayWohlfarth Member Posts: 1,702
I found this in the closet of an old apartment building we service here in Pittsburgh. It looks like something they used to bring Frankenstein back to life.
Ray Wohlfarth
Boiler Lessons
Erin Holohan HaskellSteve MinnichSolid_Fuel_ManSWEIrick in AlaskaFlyingScotsman
  • Henry
    Henry Member Posts: 998
    It is a Dunham-Bush Vacuum system with a motorised valve. This panel is in great shape. Many had setting indications masking taped on the board for what types of adjustements based by outdoor temerature.
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    This is right on my desk. From the same type of system??
    Steve Minnich
  • Dave in QCA
    Dave in QCA Member Posts: 1,802
    Fantastic! A GREAT piece of Dunham history.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    Steamhead Member Posts: 17,638
    Ray, that should be the same system that was later known as the Vari-Vac. The boiler ran up to a certain pressure and a motorized modulating valve varied the amount of steam entering the system. A vacuum pump produced vacuum up to a certain point depending on how cold it was outside. It was essentially outdoor reset for steam.
    We have plenty of info on these systems, on the site and elsewhere. Have you poked around to see how much of the system is still there?
    Consulting
    Dave in QCA
  • RayWohlfarth
    Thanks Guys. There is nothing left of the original system It has been butchered by several companies. I was looking for steam traps and found this. I would love to go back in time to see this working originally
    Ray Wohlfarth
    Boiler Lessons
  • Mad Dog_2
    Mad Dog_2 Member Posts: 7,799
    Neato.. Ray. Nice find A god number of those in The Gold Coast of Ling Islands North Shore. Mad Dog
  • Mad Dog_2
    Sorry for misspellings..hands are gettin cold out here...ha ha. Mad Dog
    Dave in QCA
