Look What I Found
RayWohlfarth
Member Posts: 1,504
I found this in the closet of an old apartment building we service here in Pittsburgh. It looks like something they used to bring Frankenstein back to life.
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
6
It is a Dunham-Bush Vacuum system with a motorised valve. This panel is in great shape. Many had setting indications masking taped on the board for what types of adjustements based by outdoor temerature.0
Fantastic! A GREAT piece of Dunham history.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Ray, that should be the same system that was later known as the Vari-Vac. The boiler ran up to a certain pressure and a motorized modulating valve varied the amount of steam entering the system. A vacuum pump produced vacuum up to a certain point depending on how cold it was outside. It was essentially outdoor reset for steam.
We have plenty of info on these systems, on the site and elsewhere. Have you poked around to see how much of the system is still there?All Steamed Up, Inc.
Consulting1 -
Thanks Guys. There is nothing left of the original system It has been butchered by several companies. I was looking for steam traps and found this. I would love to go back in time to see this working originally
Ray Wohlfarth
Boiler Lessons0 -
Neato.. Ray. Nice find A god number of those in The Gold Coast of Ling Islands North Shore. Mad Dog0
Sorry for misspellings..hands are gettin cold out here...ha ha. Mad Dog1
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
