Advice needed on used indirect water tank - any risk is buying used?
I am in the process of purchasing a new boiler and water tank. I found a slightly used Crown mega-store for sale locally. I am told it was used for 2 years before the boiler he bought failed. The contractor I am planning to work with quoted 2600 for the water tank, parts and instalation. His brand new tank is a wiel McClain the same size. He said he would deduct 900 to install the used one. I would save $600 dollars. Is it worth it?
  • kcopp
    kcopp Member Posts: 4,630
    A few things....
    - Used tank has NO warranty. Only to the original purchaser.
    - Depending on the water quality you could get some nasties in the tank.
    - if the tank was outside the coil if left full of water may be damaged.
    - if you have issues you will have to pay out more....
  • Bob Bona_4
    Would not recommend it.
