Expansion tank brackets
njtommy
njtommy Member Posts: 1,105
Hey guys I'm looking for expansion tank brackets like this one here. Any idea where to find them?
Thanks for the help.
http://www.regulusromtherm.ro/ro/expansion-vessel-mounting-arm-complete
  • Bob Bona_4
    The giant hose clamp/bracket setup ng?
  • njtommy
    Thanks @Hatterasguy
    @Bob Bona I want something that looks nicer.
  • Paul S_3
    Paul S_3 Member Posts: 1,292
    edited November 2016
    @njtommy why not try a local suppky house....plumbing supplies by me stock both types....i know johnstone supply has them since your in nj.....i like the bracket type better....the type in your pic above is more expensive and requires plugs, air vents etc too which do not come with the setup....i would just get a bracket type like the hydroclaw or the hose clamp type.
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • njtommy
    @Paul S I tried local supply house they said they've never seen a bracket like that. I was hoping to use something different that looks good.
    I will double check johnstone. Thanks.
    hot_rod Member Posts: 27,100
    I have seen those at supply counters across the US. Ferguson, Denver was on place.
    Rathe Associates on Long Island carries this Calefactio brand.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    I always used a 10" Unistrut pipe clamp (galvanized) and 1-5/8" strut. Too much torque on two screws for me with those wall claws. I like spanning at least two studs.
    ME
    Are you looking for just one, or an ongoing source? I have some samples of this Caleffi brass version. It came in a little $$ so we don't bring them over.
    I adjusted the metric connections.
    Fill valve screws in the bottom, has a check valve for the expansion tank for removal and service. You are welcomed to one.
    The HydroClaw that the Perry boys manufac
  • njtommy
    @hot rod
    I definitely need 1 for now on a job that I need to go back on and finish, but if they aren't available here don't worry about it. I would like to try and get my main supplier to get them for me. As I told them with the Taco VR and VT pumps if people know or see you stock them you will sell the pumps.
  • Jeff Perry_3
    Jeff Perry_3 Member Posts: 102
    I realize this thread is a few months old but if you're interested in the HydroClaw I would love to talk to the supply house in your area and see if they would like to carry our bracket.
    Thanks
    Jeff
    Storm King Enterprises
  • njtommy
    edited February 2017
    Thanks Jeff I've actually ordered a couple of the hydro claws from supplyhouse.com. Just so I have them when needed. You guys make a nice product thanks.
  • JohnNY
    JohnNY Member Posts: 3,346
    I'm bringing this thread back to life. Any new favorites out there? It seems Axiom makes the most comprehensive bracket assembly but it's not available for several weeks.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Zman
    Zman Member Posts: 7,611
    Albert Einstein
    Steve Minnich
    What do you think of this bracket I designed it to be used for potable or hydronic, its stainless.
    1/2 & 3/4 tank connections, 1/4 for rear mount pressure gauge, fill valve connections.
    Steve Minnich
  • JohnNY
    Sweet! I'll take one.
    Classes
  • Steve Minnich
    Steve Minnich Member Posts: 2,869
    I used the Flamco AND the HydroClaw on my own system just because.
    Steve Minnich
  • JUGHNE
    JUGHNE Member Posts: 11,527
    How about support for the ASME exp tank? The ones that look like a small "Fat Boy". Looks to be the physical size of a ST-12.
    I have one about 12' off floor, can't get to it unless I haul the ladder in to redo some other plumbing.
    Brilliant installation....completely engineered in 1997.
    Installed by company more than 100 miles away so you know they were "pros".
    You have to shut the entire K-12 school off to remove it.
    No check valve anywhere.....wasn't needed then.
    But will be necessary with piping corrections.
    pabmanrique
  • GroundUp
    GroundUp Member Posts: 2,483
    I suppose it depends on the installation, but I have yet to find anything better than the HydroClaw for what I do. They're darn spendy, but then again so are the arms and the arms take WAYYYY more labor.
