Lowest Stack Temp.
What was the lowest net stack temp. on oil fired unit you have ever encountered ?
Thanks
Jay
    Steamhead Member Posts: 18,170
    if it's less than about 325-350° F or so, it's too low, and can cause condensation in the chimney.
    Consulting
    SWEI
    Jamie Hall Member Posts: 26,707
    And that condensate is truly evil stuff. Even with low sulphur oil, there is some sulphuric acid. Also nitric. Also carbonic. It will eat through almost everything!
  • SuperTech
    SuperTech Member Posts: 2,633
    I saw 275 degree stack temp once. It was on a Buderus blue flame burner. It was crazy. I thought my Testo 320 was malfunctioning!
  • rick in Alaska
    rick in Alaska Member Posts: 1,505
    110 degrees on a condensing Adams Furnace.
    Have had quite a few common oil fired units under 300 degrees where I had to do things to get it over 325 though.
    Rick
    A boiler or furnace which is designed to be condensing can indeed run well below 325, and do it safely -- provided it's properly installed. The materials are designed to take the condensate. If it isn't designed to be condensing, though...
