Radiator shutoff valve size
tgbrew
tgbrew Member Posts: 43
I hope this isn't a really dumb question but I couldn't find the answer in the archives after many searches.
I'm adding a radiator on a one pipe system and picked up a nice old one but it looks like a 1" hole for the valve. I planned on 1.25" supply. Should I reduce somehow to use a 1.25" shutoff valve? Or get a 1" valve and reduce the pipe before the valve?
Or should I consider piping 1" pipe to the radiator? (I would rather not as all other rads in our house are 1.25" and I may want to swap out radiators)
  • Size matters, as they say. Bigger is better. Best to remove the 1" bushing from the newly acquired radiator (usually by carefully cutting it out) and replacing with a 1-1/4" bushing. All set.
    New England SteamWorks
    newenglandsteamworks.com
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,929
    If it has a bushing, definitely remove it and use the larger valve. It not only allows you to use a larger valve and supply pipe, but it allows the radiator to drainmore completely. With a concentric bushing in the bottom fitting, you always end up with a puddle in the bottom of the radiator.
    I've been doing this with my own radiators. Even if the supply is only 1" or 1¼", I've replaced them with 1¼" or 1½" valves, because the new valves simply aren't as big as they used to be.
    This is a new 1¼" valve next to the one that was on my radiator:
    Rather than using the smaller valve, I got a 1½" valve and put the bushing from the radiator in the bottom of the valve.
  • tgbrew
    So you think I should throw out this old fancy eccentric bushing and replace with a 1.25"? I'm not sure I can find an eccentric bushing without significant delay but will wait if needed. Otherwise would a regular black iron concentric work? This old one looks like it is going to be fun to get out...
    I'm including a pic.
  • Hap_Hazzard
    I've never seen one like that before. Mine have all been concentric. I'd still remove it, if I could get it out intact, and install the larger valve.
