seasonal maintenance
rmoore007ri
Member Posts: 45
Make sure the boiler water is clean. Drain a little water from the drain valve on the boiler to remove any sediment. Look for any leaks around the boiler and along any piping/valves/fittings. Fire it up and make sure the main vents and radiator vents are all working properly and that the LWCO, Pressuretrol, Auto water feed function properly. Not a bad idea to have a Pro check and clean the burners, do a combustion test and adjust as needed.1
