seasonal maintenance
rmoore007ri
Member Posts: 45
Make sure the boiler water is clean. Drain a little water from the drain valve on the boiler to remove any sediment. Look for any leaks around the boiler and along any piping/valves/fittings. Fire it up and make sure the main vents and radiator vents are all working properly and that the LWCO, Pressuretrol, Auto water feed function properly. Not a bad idea to have a Pro check and clean the burners, do a combustion test and adjust as needed.1
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 79 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 887 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 41 Industry Classes
