Leaking bleeder valve in 1st floor replace or plug
bink
Member Posts: 97
Simple question - the air bleeder in the 1st floor loop is leaking water . Question plug it or replace it. Have not had a problem with air for a long time so i am thinking install a plug. Do not do this work myself but like to get a opinions from heating help. I have learned alot from this site and do appreciate your advice
Thank you my new system with latest thinking on piping pump away does work good no air problems thanks for advice0
I too will attest to microbubble eliminator. I installed a spirovent while still pumping away, has standard watts iron air eliminateor before had chronic air problems. Spirovent took care of all air in two weeks. I install them on all my jobs now. We'll worth the money. Other companies make microbubble air eliminaters as well, I just used the spirovent brand.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0
