Jotul gas fireplace, blower keeps cycling on/off
Jza1736
Jza1736 Member Posts: 4
I have a Jotul gas fireplace. I had it off for the summer. I lit the pilot light last week. For some reason the blower (controlled by a Snap disc thermostat), keeps cycling on 5 min / off maybe 20. It's acting like the main flame is on, but it's not. Only the pilot light is on.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Where is the snap disk located relitive to the pilot? Is the pilot the correct size according the the manual? Also there should be a temperature printed/stamped on the snap disk, check the location on the fireplace to confirm if it's warm enough to activate the disk.
    Taylor
  • Jza1736
    Directly underneath it.
    Yes it's OEM. It has worked perfectly for 2 years (bought the house with the unit)
    I would have to remove it to get the temps. I believe it's working, because the blower is turning on and off?? Would it turn on if the disc is not working?
    Thanks for your help
  • Solid_Fuel_Man
    How warm does the unit get in the area of the snap disk? The snap disk may be defective and turning on too early, or there may be a draft problem causing the fireplace to become too warm with just the pilot running.
    Is this a direct vent unit or is there a vertical flue, lined wood burning fireplace chimney. Can you inspect the vent for any blockage such as nests etc?
    Taylor
  • Jza1736
    This is a direct vent unit. I will check the vent after work. I was thinking the thermostat also. But just wanted another opinion. Thank you
  • Jza1736
    I checked the outside vent. It's clear and there's a screen that will keep out critters. The inside would require taking apart the unit. Does the inside get clogged?
    I'm leaning towards the snap disc thermostat.
