Please help me find this part for sale
duk3
duk3 Member Posts: 3
edited October 2016 in THE MAIN WALL
First - thanks for all of the shared knowledge and help. I've read a lot on this site and learned a ton.
I diagnosed a Crown Boiler (aka "Velocity Boiler Works" (I think?)) Bermuda (BSI) 138 gas fired steam boiler as having a bad gas valve. In the time it took to aquire a new gas valve, someone threw out the manifold. I've looked for hours and have no leads on where to get a new manifold. Any help?
Here's the boiler: https://www.johnstonesupply.com/storefront/product-view.ep?pID=L99-650
Here's the installation manual: http://www.velocityboilerworks.com/documents/bermuda_installation_manual.pdf
Page #44 of the manual above shows the part I need with the number 43. Preceeding page #43 tells me that the part is a "MANIFOLD (1" BURNERS)." many part numbers then follow because this manual is for multiple size Bermuda boilers. The part number for the manifold I need is listed as 700155.
THANKS!
  • STEVEusaPA
  • duk3
    Thank you Steve. I've looked through that website thoroughly without finding the part but perhaps you only provided the link with the intent to say I should contact Velocity Boiler Works? Or is the part somewhere on that site and I'm missing it?
    Thanks.
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    edited October 2016
    where are you located....?....the BSI crown boiler is a pretty new boiler....that part should be obtained pretty quick....any crown dealer should be able to get you that part.....are you a contractor?
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
    duk3
  • STEVEusaPA
    Usually you have to buy from crown directly, I least that was always the case for chambers. They're here in Philly so not a big deal for me.
    I would call them and ask.
    duk3
  • duk3
    Ok thanks to you both.
    I am not a contractor and I'm in North NJ near Newark. Now that it's Monday, I'll call Velocity Boiler Works to ask them how to purchase.
