Please help me find this part for sale
duk3
Member Posts: 3
First - thanks for all of the shared knowledge and help. I've read a lot on this site and learned a ton.
I diagnosed a Crown Boiler (aka "Velocity Boiler Works" (I think?)) Bermuda (BSI) 138 gas fired steam boiler as having a bad gas valve. In the time it took to aquire a new gas valve, someone threw out the manifold. I've looked for hours and have no leads on where to get a new manifold. Any help?
Here's the boiler: https://www.johnstonesupply.com/storefront/product-view.ep?pID=L99-650
Here's the installation manual: http://www.velocityboilerworks.com/documents/bermuda_installation_manual.pdf
Page #44 of the manual above shows the part I need with the number 43. Preceeding page #43 tells me that the part is a "MANIFOLD (1" BURNERS)." many part numbers then follow because this manual is for multiple size Bermuda boilers. The part number for the manifold I need is listed as 700155.
THANKS!
THANKS!
Thank you Steve. I've looked through that website thoroughly without finding the part but perhaps you only provided the link with the intent to say I should contact Velocity Boiler Works? Or is the part somewhere on that site and I'm missing it?
Thanks.0 -
where are you located....?....the BSI crown boiler is a pretty new boiler....that part should be obtained pretty quick....any crown dealer should be able to get you that part.....are you a contractor?ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
Ok thanks to you both.
I am not a contractor and I'm in North NJ near Newark. Now that it's Monday, I'll call Velocity Boiler Works to ask them how to purchase.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 974 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
