Glass steam header
Ironman
Member Posts: 7,850
Some years back, someone posted a video of a glass steam header where you could visibly see what takes place when steam is generated. I believe it was produced by Weil McClain?
Can anyone provide a link to it?
Bob Boan
Did you mean this one:
https://www.youtube.com/watch?v=1loCscHGiRo There was an error rendering this rich post.
Here is another one for your viewing pleasure and edification:
https://www.youtube.com/watch?v=wWxRkIHTV4k All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc1 -
Now that's cool!0
What I find interesting is according to the Spirax Sarco videos that should not be happening when a boiler is working correctly. The only time their boiler throws anything but steam up into the piping is during excess load or from water problems.
On my own WM EG-40 boiler, adding too much Steamaster caused my pressure to rise much above normal, removing the excess dropped it back down. I can only assume that pressure was caused by water going up the risers which reduces the space steam can escape.
At around 1:25 you can see foam getting sucked up into the riser.
https://youtu.be/gBNeIBgVfvk?t=1m17s
Here's the high demand one which looks like what's going on in WM's glass setup.
https://youtu.be/8Lmagejlc1s?t=39s
I'm not an expert on this, and I've never even had a glass header but based on what I assume is going on with my own boiler when I use too much treatment vs normal, as well as those Spirax Sarco videos, it seems like the boiler with the glass piping has undersized risers way too close to the water line and this is causing a ton of water to be sucked up with the steam. My understand is under normal operation in Spirax Sarco's videos their boiler is never puking it's contents up into the piping except when something is wrong.
@Hatterasguy Thoughts??
Perhaps this is a very good demonstration of exactly what a steam chest does, and why an oversized header and risers is so important on modern residential boilers?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
https://youtu.be/T7zPbcO_ETY
