Gravity conversion?
Paul S_3
Member Posts: 1,288
the pics below show a radiator, return elbow on a radiator and a main with standard 2.5 tees pointed on a 45 degree angle downwards these from @Dan Holohan s books i know right off the bat was for the upstairs radiators.....i gave 3 quotes (1) stay with gravity using a weil mclain (knockdown) CI boiler ......(2) convert to pumped circulation with a atmospheric CI boiler and 4 way Taco ISERIES on constant circulation......(3) which is the most ideal was convert to pumped circulation using modcon Lochnivar khn .....system pump on constant circulation......which setup would you guys go for? any advice? Do you guys think these are standard return elbows? orifice plates on top floors? i did not open radiator valves or return elbows yet.....when converting to pumped circulation can i run into any problems.....system not open to atmosphere.....theres a steel compression tank at boiler.....thanks for any input....ive seen @gerry gill install a straight gravity boiler using a Honeywell #1 heat generator.....maybe you have some tips too.....never converted or replaced a gravity system . boiler...heat loss for home is no more than 100k at most from experience....every radiator is similar to the one in the pic all from 25 sections the smallest rad to 40 sections the largest .thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
That's an odd set up. I could see a return looking like that, but in your photo they tapped off the supply and return, more or less, from the bottom of the pipe.0
I think they did that to slow down the circulation to the top floors ...so the lower floors heat pretty much the same time for system balancing.....that's why I don't think there's orifice plates in the top radiators....never done this conversion before ....just looking for tips... what to look for etcASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Is there working valves on the radiators? It probably seems like a stupid question, but when you pump those systems, they can make it much easier to balance the system.0
That is a piping method of slowing down gravity flow. Your assumptions are correct.0
yes valve work ...I may have to change a few 1 inch angled ....but for the most part yes they turn....I couldn't run the system no oil in tank....this is an oil to gas convo.....hopefully this guy can understand the value in my proposals.....company can just go in there for 1/3rd the price and bang out installASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
As far as your offerings have you done, or will you do a radiation survey? How is the owners budget constraints? Has there been envelope upgrades?0
no EDR survey until deposit is collected.....I agree with the valve testing....just would like to be prepared if they want convo....never done gravity to circulation beforeASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
no envelope upgrades.....plaster lathe walls.....heat loss maybe in the 125K zone...proposal covers even larger if anythingASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
It's a huge manifold system. Keep it simple.0
thanks.....guysASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
That's an ideal candidate for a mod/con. No great mystery involved in converting it to forced flow.
Flush, flush, flush with water until it runs clear. That will involve installing purge valves with the new boiler. Use a magnetic strainer to catch what flushing doesn't. The new near boiler piping can be sized by cutting the size of the gravity in half, then go one pipe size smaller. In other words, if it's a 4", then 1/2 of that would be 2" - one size = 1 1/2".
One ups15-58 or equal circ can probably carry everything unless your boiler requires p/s.
Somewhere on here years ago, I posted about 10 things to do on a gravity conversion. A search should locate it. Dan also has some articles about it under the resources tab.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.-1 -
thanks BobASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
