Anyone making Nickel plated plain radiator valves?
The Steam Whisperer
Member Posts: 1,218
Installing some new modern radiators in a very nice residence and they don't like the look of the bare brass or bronze radiator valves. These have to be packless because its a vacuum system. Plenty of trvs' are plated, but I haven't seen any manual valves that are plated.
Why do the valves need to be packless, and what's wrong with having no valves-just TRV's?--NBC0
We take valves to a local plater and get them done after market.gwgillplumbingandheating.com
The TRV would look good and it sounds like it might fit into the budget compared to platting. However are TRV's tight enough to hold a vacuum??0
Packed type radiator valves tend to leak air in vacuum systems, so were not used. I am concerned about the TRV's because they have such a small orifice, so steam will tend to favor the non-TRV radiators. I think most if not all TRV's are vacuum rated.
It looks like custom plating might be necessary, like Gerry said.To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 853 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
