Any oil boiler recommendations, for part-time heat, would be appreciated!
Afternoon guys...first time poster.
I heat my 2000sqft home with high ceilings in central NY primarily with wood heat. However, when it is super cold <0F and we are out of town, we need a new oil boiler. My 25 yr old Utica boiler has seen better days.
Because this boiler will be used a couple of times a month in the winter, I'm not really worried about having the best performing efficiency, since I will not see the payback. I want a solid performer that will come on when I need it to come on...every time. Reliability is my primary concern without breaking bank. Cost is a concern. 1 income and 2 kids. :)
My needs are 75,000-100,000BTU. I would prefer to stay on the smaller side and run it more reguarly. The previous boiler was 105,000BTU and also heated the potable water. I have since installed a hot water heater and removed that need from the boiler system.
Thanks guys!
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    Buderus G115
  • Danny Scully
    Danny Scully Member Posts: 1,465
    Hot water or steam?
  • sportbikerider78
    sportbikerider78 Member Posts: 2
    Hot water.
    An air leak developed on the Utica,,,this was where the burner flange meets the boiler. It appears that it warped the boiler and has me a tad sketched out.
    I bought the house 3 years ago and the boiler cuts in and out occasionally. I think it is time for a replacement, but it does not have any water leaks.
  • STEVEusaPA
    Hot water.
    I've never heard of anything like that. Can you post a picture?
