Erie Valve Wiring
bbilodeau
bbilodeau Member Posts: 2
I'm installing an Energy Kinetics System 2000 and using Erie zone valves. Both leads are black although they connect to blue and yellow wires on the motor. Is there a positive and negative or does it not matter? Thanks.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    edited October 2016
    Does not matter as the valve is 24 volts ac.
    Taylor
    hot_rod Member Posts: 27,472
    Are there two or four wires coming out of the Erie valve?
    A 24V valve?
    If only two, those are for the motor, no polarity.
  • bbilodeau
    It is a 24V two wire, so no polarity, thanks!
