Erie Valve Wiring
bbilodeau
Member Posts: 2
in Oil Heating
I'm installing an Energy Kinetics System 2000 and using Erie zone valves. Both leads are black although they connect to blue and yellow wires on the motor. Is there a positive and negative or does it not matter? Thanks.
Does not matter as the valve is 24 volts ac.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Are there two or four wires coming out of the Erie valve?
A 24V valve?
If only two, those are for the motor, no polarity.Bob "hot rod" Rohr
It is a 24V two wire, so no polarity, thanks!0
- 120 Geothermal
