Quick leak fix for pipes on MSN post
Something that popped up on MSN that I thought plumbers might like....
http://www.msn.com/en-us/video/tunedin/a-plumber-invented-a-clamp-that-instantly-fixes-leaking-pipes/vi-BBwd5dZ
Seems great as long as it's not in my house.
I almost never see leaks in locations like that. In the middle of straight lengths of pipe and not near fittings, elbows, tees etc.0
Not really any different than the saddle clamps that have been used for the last 100 years on galvanized pipe.0
Was wondering if it was just a gimmick. Sounds like they took something old and re-did it. I've only see a leak like they show on a pipe that had been frozen.0
Every once and a while a careless carpenter will drive a nail in an area and hit a water pipe or on rare occasion a copper pipe will spring a pin hole leak. If that clamp is exposed where you could keep an eye on it, or as a quick emergency fix, it's probably okay. Always better to cut the pipe and sweat a coupling in though.PinkTavo said:Was wondering if it was just a gimmick. Sounds like they took something old and re-did it. I've only see a leak like they show on a pipe that had been frozen.
Only because a careless plumber ran a pipe through a stud without a nail guard........Fred said:
Many, many do! Especially on retrofits. Besides, there are literally millions of homes out there that were plumbed before someone came up with the nail guards, not to mention those copper pipes fastened vertically along the side of a stud or horizontally along a floor joist.0
@Danny Scully I come from a family of carpenters but I'm not biased
@Danny Scully the 4 inch nails get used when it's"weight bearing" trim. At least, it was in my house.Danny Scully said:@ChrisJ, what about when carpenters use 4" molding nails, is that the plumbers fault too?
I tell ya, it's that kind of outside the box thinking that makes life great. lol You can have it good, fast or cheap. Pick two0 -
or just press a coupling in that way it if water is their it won't affect it. years ago i used to use a ips by sweat t to allow the steam and water to escape0
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
