Prepiped 3" drop header
Great looking job Ezzy...i really like the 45's ...touch of classgwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.2 -
Thanks @gerry gill that's an honor coming from you.2
Repipe completed with 2 stage firing set up.3
What did you use for the two stage firing Ezzy?gwgillplumbingandheating.com
Robertshaw 700-053 two stage gas valve and of course a vaporstat which you can see in the picture.0
@EzzyT I might have missed it earlier but that's an EG right? which one?0
Looks Fantastic!0
nice install @EzzyTASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
It's not always necessary to 2 stage fire a boiler, in this case the existing boiler is over sides by quite a bit so we have it set up when the system reaches a 8oz the gas valve switches into low fire and firing at 60% of its rating and stays there to maintain pressure in the system (long cycle) until the thermostat is satisfied. We've seen a significant savings in our customers heating bills that do choose to have this set up done.1
Looks perfect Ezzz......DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Wow. Super clean install. Very nice0
- 110 Chimneys & Flues
- 980 Plumbing
- 387 Solar
- 17 Recall Announcements
