Location of boiler riser versus controls
The Steam Whisperer
Member Posts: 1,216
The Weil Mclain instructions for the EGH and LGB have me really confused. They require the steam supply riser to be located on the same side as the controls. This would place the low water cut off at the highest water level area of the boiler ( just below the supply tapping). This would leave the other end of the boiler much more likely to experience low water without the control shutting it off.
Am I missing something here or are they just putting priority on the boiler not overfilling?
You are spot on. Doesn't make sense. Better to flood the boiler then expose boiler to dry firing. Non of this is relevant if boiler is even close to properly piped0
Doesn't make sense to me either, but if I had to guess, it stems from a lawsuit somewhere.
At any rate, I always pipe both risers and use the return side that best suits my design without consequence.New England SteamWorks
newenglandsteamworks.com0 -
O
And controls end up where? On the return side?RI_SteamWorks said:Doesn't make sense to me either, but if I had to guess, it stems from a lawsuit somewhere.
At any rate, I always pipe both risers and use the return side that best suits my design without consequence.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
