For Old Heating System Sleuths
And for that reason, finished basements drive me nuts. Which is what I have in this case.
It's a beautiful house that seems largely intact. Two-pipe system as previous stated. But none of the radiators match, though the traps all do (Webster). Not even on the first floor in the main rooms do they match. No signs of any heating system prior to the existing.
And then we have this:
It's a steam heat exchanger with a blower and 3 ducts to three floor vents, one in the parlor, one in the front foyer and one in the 2nd floor master bedroom. It was important enough to install that a door behind the unit was walled over so as to allow it's installation. The 3 rooms with the floor grates have massive radiation, so why?
The unit is disconnected, probably has been for a very long time, and is not of any import beyond being a possible piece of the puzzle that this house represents. My customer purchased the home over the summer so there is no history.
newenglandsteamworks.com
Could have been for fresh air into the house. Any evidence of ductwork or outside inlet grills?0
I agree.
This is probably a Webster Modulation system (If it doesn't have a Return Trap) or a Type R system (if it does). Pretty standard Vapor in either case.
How about some radiator and boiler room pics?All Steamed Up, Inc.
Consulting0 -
Is that a direct drive motor on that blower? Maybe the fresh air was an afterthought? Also did the house have electricity in 1914?0
1. If there was ducting to bring fresh air in, there is no sign or clue of it now.
2. There is a trap on the return.
3. The house likely had electricity when built, but the blower is not original because a door was walled off in order to install it.
I suppose it could have been added simply to bring in fresh (warmed) air into the home? That would make sense if someone was really concerned about stale air, especially given the location of the vents in the home.
The requested photos:
New England SteamWorks
newenglandsteamworks.com0 -
Maybe it was a heating guy's house and he used whatever he had on hand as long as the radiators were about the right size?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
Looks like remains of a trapeze hanger for a ceiling/condenser radiator above the boiler.0
@JUGHNE, I was thinking the same.0
Consumption, or what we now call tuberculosis, was raging in the U.S. then, and fresh air was a part of the remedy. Note the location of the vents in this house. Someone who lived there was ill.
http://www.faculty.virginia.edu/blueridgesanatorium/death.htmRetired and loving it.2 -
I am going with that Dan, makes perfect sense, thank you. A doorway wouldn't stand in the way of an illness.
I couldn't read the model number of this Utica. Anyone care to venture an approximate age?New England SteamWorks
It's an OU-something. Count the number of sections to complete the model number: 4 sections= OU400, 6 sections= OU600. Some of the larger units had model numbers starting with HS rather than OU, but I don't think yours is that big.
These boilers were built like tanks.All Steamed Up, Inc.
Consulting0 -
Consumption was big business here in our little corner of NMDanHolohan said:Consumption, or what we now call tuberculosis, was raging in the U.S. then, and fresh air was a part of the remedy.
http://www.elpalacio.org/placeseries/winter08lungers.pdf
http://www.cs.amedd.army.mil/borden/FileDownloadpublic.aspx?docid=332041d7-dbd2-4edf-823f-29a66c0b65ef
The only thing I could make out was 1035 sq ft of steam. I am guessing from the 1960's?Steamhead said:It's an OU-something. Count the number of sections to complete the model number: 4 sections= OU400, 6 sections= OU600. Some of the larger units had model numbers starting with HS rather than OU, but I don't think yours is that big.
Amazing how putting something in its historical context clarity to an enigma.DanHolohan said:Consumption, or what we now call tuberculosis, was raging in the U.S. then, and fresh air was a part of the remedy. Note the location of the vents in this house. Someone who lived there was ill.
Dan, I think you could probably earn a graduate degree in history of technology without too much difficulty.Just another DIYer | King of Prussia, PA
LOL! Thanks, Hap. I'm just curious.Retired and loving it.0
Negative.DanHolohan said:
A book like your lost art, or greening steam. The history of how and why they were engineered the way they are. How they were sold, financed etc and most importantly, how to make repairs.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Okay. Thanks.Retired and loving it.0
some very cool history in this thread!gwgillplumbingandheating.com
That would be either an OU-800 or an HS-800 depending on what burner was originally on it. Firing rate is 3.05 GPH if running at maximum rated load. Probably dates to the 1970s or early 1980s.RI_SteamWorks said:
Consulting1 -
Keep talking. ;-)DanHolohan said:Writing has never seemed like work to me. It's just talking on paper, a joy.
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-243
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
