Boiler System filled with water
ChadV
Member Posts: 1
I just bought a new house. The water was turned off when we moved in. When the water company turned on the water, the manual fill was completely open on my boiler for about five full minutes until water started coming out of the overflow. The water company guy noticed and turned it off, but my boiler system completely filled with water by that time. To make matters worse, the boiler drain is clogged. Am I in trouble? The water is just sitting in there. I can't get it out and can't get someone to look at it for a week.
where are you located? does this boiler heat your domestic hot water? this should be an easy fix.....ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
There isn't an overflow. There is a pressure safety valve, but it would take ALOT of water to make that leak unless it was going bad already. Could you post a picture of where the water came out?ChadV said:I just bought a new house. The water was turned off when we moved in. When the water company turned on the water, the manual fill was completely open on my boiler for about five full minutes until water started coming out of the overflow. The water company guy noticed and turned it off, but my boiler system completely filled with water by that time. To make matters worse, the boiler drain is clogged. Am I in trouble? The water is just sitting in there. I can't get it out and can't get someone to look at it for a week.
If your boiler drain is clogged you probably want the boiler serviced for sure. That indicates you have a ton of crud in the boiler that should be cleaned out. As Paul said where are you located and we may be able to recommend a good steam man in your area.
1
